EQS EQS (V297) sedan
Front Camera Lens Cracked
Old May 27, 2025 | 04:40 PM
matts's Avatar
'23 EQS 580
Smile Front Camera Lens Cracked
Had the unfortunate instance of a rock hitting the front camera just right and cracked it, making the image pretty unusable.
There were two options ... take to dealer for a fix ... or do it myself. I chose fix it myself and it was actually pretty easy and save some $'s.
The part was easy to find on Ebay ($50) and even quicker to swap out.
MB part number for my 2023 EQS 580: A0009055912 (mine had the 21/13 HW version but what I got was newer but still worked just fine.)
Steps:
1 - Pop the hood and brace it up
2 - Remove the light bar, 3 Torx screws and two electrical pigtails to disconnect.
3 - Reach down from the driver side in front of the radar unit and give a slight push on the MB emblem that houses the camera. The piece is held in with a couple clips that as you push from inside give up nice and easy, they did not break even after removing a few times.
4 - Disconnect the wire to the camera (this was a little tricky to pull the connector release to get the connector to release.). You can leave the defrost connected wire under camera connected.
5 - Pop up the camera retaining clips, one on each side, a little press and they release and the harness rotates out of the way
6 - Replace them camera with the new one, keep the same orientation.
Reverse all the above steps to put it back together.
The good news, after buttoning it all up and checking out the image, all was perfect and no calibration was needed. Ton of $'s saved in the material and labor. On a DIY scale of 1-10, this was easily a 2 or 3 in difficulty, the hardest parts were propping up the hood and getting the connector on the camera to release.
As a side note, MB uses the same cmaera on lots of vehicles, so easy to find replacements pretty cheap, vs the $600-$800 I found from some of the MB parts websites.
If anyone gets in a jam and needs some pictures, let me know and I redo this process to grab some.
-Matt
Old May 27, 2025 | 07:58 PM
W205C43PFL's Avatar
Steps:
-Matt
Sorry to hear about it but thank you for posting a tutorial.
Old May 28, 2025 | 12:45 AM
c4004matic's Avatar
17 E43; 21 GLS580
Steps:
-Matt
Good info
Old Jun 24, 2025 | 09:05 PM
Pkmnplayer's Avatar
I just had this happen to me and the dealership quoted me just a bit over $1650 to get it replaced. Why have a protective layer over the camera if you need to replace the camera as soon as the protective layer is damaged? Anyway, mine is a EQS sedan and I was wondering how experienced you were to get this fix done yourself? Did you need multiple people?
Old Jun 24, 2025 | 09:18 PM
matts's Avatar
'23 EQS 580
it was very easy and does not take much experience to swap out. Just a few simple tools and a way to prop up the hood. Total cost was less than $100 and less than 20 minutes to swap.
Old Jun 24, 2025 | 09:39 PM
Pkmnplayer's Avatar
Oh cool! I'll order the relevant part and see if I can get cracking at it. You didn't have to remove the bumper right? Does the part differ from SUV to Sedan? From my research, it doesn't, but just checking.
Old Jun 25, 2025 | 06:16 AM
matts's Avatar
'23 EQS 580
Bumper did not have to be removed, only the light bar which was really easy.
Old Jun 25, 2025 | 02:08 PM
MB37's Avatar
23' EQS AMG
When mine cracked, my challenge was not having the knowledge of removing the MB logo/camera from the grille. I removed the light bar and could see the camera and grille but was afraid that I might break a clip or two if I didn't know how to remove it from the grille to remove the camera. In addition, others were saying that it needs calibration despite my intuition.
In the end, I bought an OEM camera from Ebay for less than $200. Be careful because there are a lot of them that looks like OEM but are made in China. The image quality is not good. It's almost better to buy a used OEM camera from a wreck MB than a new one made in China. My dealer installed it for free because they were doing some other work for me and charged me $$300 for calibration. Otherwise, installation would have been $150.
If you get the camera from the dealership, it will be very expensive and is the bulk of the cost for the turnkey job.
Old Apr 16, 2026 | 02:55 PM
riosparada's Avatar
What color are the clips and which way do you push them
Could you please tell me what color the clips are and which way you push them and how many are there?
