Tire Pressure Monitor Nuisance
If you reset TPMS when tires are at about ambient temperature, cooling down overnight should neither trigger any warning.
That's a frustrating issue, and a very unusual one for these cars. The other members have provided the excellent foundational advice—checking the pressure cold against the door jamb sticker is always the right first step.
However, your specific problem, where the warning triggers on both a 1-2 psi increase and decrease, points to a more nuanced issue that is common on these vehicles. It's likely not a faulty sensor, but a conflict between the car's two different sets of tire pressure recommendations.
Here's the deep dive on what's likely happening:
The "Two Sticker" Paradox
On these cars, Mercedes provides two different inflation standards, and they serve two different purposes:
- The "Normal Load" Sticker (The Legal Requirement): This is the main placard on the driver's door jamb. It lists the pressures required to safely carry the vehicle's maximum load. Think of this as the Safety Standard.
- The "Comfort" Sticker (The Mercedes Recommendation): This is often on the same placard or inside the charge port door and lists a lower PSI for a softer, more luxurious ride under a light load (e.g., just the driver). This is the Experience Standard.
The Definitive Solution: The J_Boxer TPMS Accuracy Test
To confirm this and get it fixed, here is a clinical method to use.
- Go to any Mercedes-Benz service drive. They will do a complimentary tire pressure adjustment.
- Provide a Specific Target. Before they touch the car, pull up your TPMS screen. Tell the technician, "Please set all four tires to precisely 41 PSI" (or whatever your higher "Normal Load" pressure is).
- The Direct Comparison: Have them use their professional, calibrated gauge to hit that exact number.
- The Immediate Verification: Before driving away, check your TPMS screen again. If you asked for 41 PSI but your screen now reads "38 PSI" on one tire and "41 PSI" on the others, you have definitive, unimpeachable proof that the sensor on that specific wheel is faulty or out of calibration.
Hope this deeper dissection helps you get to the bottom of it.
I have a personal case study that perfectly illustrates this.
Recently, I was preparing for a 12-hour road trip to Florida. The car was fully loaded—overloaded, really—with passengers and luggage. Following protocol, I inflated the tires precisely to the higher "Normal Load" pressure recommended on the door jamb placard for a vehicle at its GVWR.
The result for the first five hours of the trip was, to be candid, an unacceptably uncomfortable ride. The higher pressure made the suspension feel harsh, transmitting every minor road imperfection directly into the cabin. It completely destroyed the "magic carpet" feel that is the hallmark of this car.
So, I made a conscious, calculated decision. I pulled over and lowered the rear tire pressure by a few PSI.
The result was an immediate and considerable improvement in ride comfort, which made the remainder of the trip vastly more enjoyable.
Now, let's be clear: was this a potential compromise on the absolute letter of the safety guidelines for a vehicle at maximum load? Yes. Was it a necessary adjustment to restore the inherent nature of the luxury car I had purchased? Also yes.
This gets to the very heart of the ownership experience. The specifications on the door jamb are not just numbers; they are the bookends of an engineering trade-off. One end provides maximum load-bearing safety, and the other provides maximum comfort. The true art of owning these vehicles is understanding this trade-off and knowing how to make an informed, real-world decision based on the conditions.
The car is engineered to be both safe and luxurious. Sometimes, as the owner, you have to be the one to decide which of those two perfectly engineered characteristics gets priority on any given journey.
