300E W124 1988
Old Mar 13, 2009 | 05:00 PM
Hanno's Avatar
6.9
300E W124 1988
I have the below still available from an 88 300E being parted out. Body is Arctic White, Interior is Medium Red. It had 229K miles on it, was running and PA inspected when I started parting it out.
ABS pump
Right front caliper
Front suspension components (no Struts or springs)
Hard brake lines
right headlight lens
Rear bearing carrier assy, L & R (service records show 10K on bearings)
Rear springs
Rear suspension components
Power steering lines and cooling hoop
sway bars (F & R)
Front frame (radiator /bumper mounting structure)
Left front fender
Right front fender
Right front door (no regulator or check stop)
Right rear door (no regulator or ¼ glass)
Trunk lid (pick up only: Middletown, DE)
OVP relay (dual fuse version)
ECU for fuel injection
Hard fuel lines
Oxygen sensor
auto trans cooler lines (no trans)
auto trans flex plate
auto trans dip stick and tube
Wiper motor and gearbox (no arm)
Horns (regular and alarm)
Sunroof and all components except motor
Windshield (pick up only, DE, you remove)
Rear glass (pick up only, DE, you remove)
Spare tire/wheel
Fuel filler door
Right taillight lens
body trim, etc.
Its pretty well picked over, but if you don't see it listed, ask anyway. Send your zip code and I'll quote a delivered price. Paypal is best, I usually ship 1-2 business days after payment.
Thanks!
hanno2s@verizon.net
