AMG Carbon Ceramic Rotors - Pair
Old Jun 24, 2013 | 09:46 AM
djson80's Avatar
sls amg
AMG Carbon Ceramic Rotors - Pair CHEAP!
On eBay now ...
http://www.ebay.com/itm/130933429547?item=130933429547&viewitem=&vxp=mtr
Incredible stopping power for your Mercedes AMG
Stopping power is vital to your vehicle’s safety on the road and there are numerous different types of braking components to improve it. These AMG Carbon Ceramic Rotors are like equipping your vehicle with thrust reverses that are activated by a press of the brake pedal.
There are several ways in which your brake rotors can get damaged. Excessive rust is a hazard in rotors made with iron, but warping seems to be the most common issue. When a rotor becomes warped, excessive heat causes a disproportionate expansion of the braking surface of the rotor. This can lead to vibration in the steering wheel and elsewhere while braking.
These rotors from Genuine Mercedes-Benz were made with lightweight ceramic. The objective was to reduce weight, the number of brakes per axle, as well as provide stable friction from very high speeds and all temperatures and these brakes accomplish that task perfectly. Composite brakes can withstand temperatures that would make steel discs bendable.
