18" Brabus Monoblock S Reps by Powerwheels Pro $529 NEW
Old Sep 5, 2011 | 09:26 AM
powerwheelspro's Avatar
Former Vendor of MBWorld
E320
18" Brabus Monoblock S reps by PowerWheels Pro
WHEEL SPECIFICATIONS: : Style 807
Size:
18x8
Offset: 48mm
Weight: ~24lbs
Hub size: 84mm
Bolt Pattern: 5x112mm
Finish: Matte Black or Silver Machined Face
Shipping: $85
WARRANTY
Our wheels are made at an OEM factory so we are proud to offer the following:
2 Years Finish Warranty: Many replica wheels finish can be sub par and the finish can crack or peel off. Since our wheels come out of an OEM process, the paint and clear coat thickness is similar to OEM standards. Obvious exclusion is curbing, denting or any other misuse that can damage or etch the finish such as use of strong chemicals in the cleaning process.
Manufacturing Defect Warranty: The wheels are made utilizing the low pressure casting process like OEM wheels do and go through rigorous quality controls including 100% x-ray, leak and balancing tests. They are guarrantied to fit on your car without vibrating or pulling.
Fitment Warranty: You don't have to know the technical specifications of the wheels your car takes, you can lean on our experience knowing what fits your car. If we get it wrong, we will support you as much as we can, or we will take full responsibility and give you a refund.
The wheels are in stock and we can also quote wheel and tire packages.
We do not make money on tires or on shipping, it is just a service we offer to our customers, we recognize not everyone has the time to drop off wheels and tires at their local tire store and waste half a day to get them mounted and balanced.
We will mount and balance them for you and take on the risk of getting it right. We have had many customers that called us after getting their wheels mounted telling us that the tire shop scratched them and asked for replacements. So we focused on putting the synergies in place that allows us to offer that service.
You can always call us at 248 686 2035 if you have any questions.
Thanks for looking!
Old Oct 27, 2011 | 07:46 PM
grane's Avatar
GLK350, SL63 AMG
What country are they made in?
Is that price per set or per wheel?
What is an "OEM factory"
Thus you make wheels for Brabus, since they are "Brabus reps?"
