How do I remove Headlight surround?
The screws only need to be loosened, not removed. Loosen the screws, then gently pull up on the surround. There are tabs at the top of the surround.
Be gentle, and it will come off fairly easily. Once removed, pay attention to the screws that you remove to change the headlight. Don't accidentally screw the adjustment screws. 3 small screws remove the headlight assembly.
