Lift questions
Has anyone used Hofele 70mm springs? New shocks required?
Thanks for any input and suggestions.
The problem you are going to run into because you have a newer G, is the computer nannies going ape **** and causing ESP to kick in because of all the sensors involved. There are a couple settings you can change to compensated, but it involves you finding a competent person with the STAR system that can change them for you. Thats tends to be easier said then done.
I know the new 4x4^2 models come with 37" tires and a lift from the factory, so I would love to see what they did at the factory to compensate for that. It might be a while though before someone on the G forums gets their hands on one to check into that.
