Beach driving ....
PS, don't drive into a pile of sand .... yeah, got that tip already!
I would just lock the Differentials and you should be good to go.
1 - Turn G on
2 - Put in Neutral
3 - Push the Big Silver Button with "1" on it
4 - Once the light is solid, push "2"
5 - Repeat for "3"
FYI, you will not have traction control (you wouldn't want it anyway).
1 - Turn G on
2 - Put in Neutral
5 - Repeat for "3"
Also, without the vehicle moving, the diff locks may or - more probably - may not engage.
Also I would not push that #3 button unless you are really in trouble or you are ONLY going straight! Do not turn the steering wheel much at all when #3 is on! The popping and crunching noise you will hear is your front CV joints breaking!
It's true that the front diff lock makes steering very stiff, but I've never broken a CV joint. Perhaps that only happens with portals.
I've never felt a need to stay in low gear on the sand because it's easy to shift down if necessary with a tap of the shifter. The worst problem I've had in the sand is going slowly sometimes but never (knock on wood) getting stuck.
Some technique that works for me is to not stop and don't try to accelerate too quickly, build up to speed. The tires you are using could also be a massive factor. If you have road tires with little grip, that could be 100% of the reason you're experiencing this. They'll slip a lot on the soft stuff. If you have p-zeros or something tiny like that you'll need to work on technique to have good results. I hope that helps.
