E55 engine/transmission in G500 conversion
What do I need to do to undertake the swap?
My technician's shop builds all kinds of top fuel funny cars all the way down to Kia bodywork. One comment my restorer has made was to keep the existing 5 speed transmission since it is in excellent condition and will keep the cost down. I will be doing this in January so I am in no hurry.
I already know I have to have the ECU wiped and the ECU reprogrammed by an MB dealer to the VIN of the rest of the truck, and then tuned to fit the car.
Please,comments like "its too much trouble" are not helpful.
I need to know the procedure so I can make a decision if the $ is worth it.
I need a step by step procedure. Thanks!
shouldn't your technician be able to figure out how to do the swap?
fwiw, it should be straight forward. I wouldn't bet on using the E55 ecu, I'd go get a G55 ecu. Otherwise, you should be ok. The trannys aren't that much different, i think theres a very MINOR difference between them. As long as you aren't pushing too much power, i.e. putting an aftermarket tune or pulley, you'll be fine with the stock trans.
Good luck and please post a diary of the process for all to see.
I'll have to look at those other threads you mention.
1. Remove the E (or G55) ECU from the car and send it to a place in NC that wipes the E/G55 VIN from the ECU.
2. The tech does the motor swap.
3. I have the G500/55 towed to an MB dealer where they reprogram the ECU/engine the same VIN as the G500.
4. The MB dealer then reprograms the ECU with a G55 tune.
The only reason I wanted to swap trannies is the newer car has a torque converter drain plug. I could always keep it as a spare. The technician suggested I use the stock G500 transmission as that would make the swap easier.
