what to expect with a 170K G500
I plan to buy a local one owner 2003 G500 with 172K miles. I know it has many miles and I will have a PPI done after we agree on a price. However, I just want to know if it is worth pursuing or if it is a money pit. I do not know much about the reliability and problems with this model year.
Thanks all
Rust is an issue (on all parts, and esp body since it is expensive to fix) on the older trucks. Rubber parts wear and cause leaks/failures as is usual. Otherwise I agree, mechanically they are great. As long as maintenance is kept up, it is no different than a lower mileage version (except you'll need to expect the usual round of higher mileage needs like spark plugs and cables, diff fluids, etc.) This mechanical robustness seems to be better than the newer 550s and any 7 speed truck. That being said, they are all victim to the same issues in terms of seat switches, lock actuators, window regulators, transfer case motors, etc...and they can add up quickly. The only oddball thing I've had pop up recently is one of my motor mounts has collapsed and I am at 118k, The bill to do all the mounts is about 1500, so not terrible.
