G500 Coupe Engine issues ??
Old Dec 29, 2017 | 01:09 PM
Gkuban's Avatar
2000 G500
Hi all,
I am desperate for some help with my G coupe please
It is a japanese spec 2002 model G500 ; currently driven around in Abu Dhabi
The issue I’m having is the engine dying while the wagen coasts to a stop. Usually happens when coming to a stop light, or parking, never at speed or on the gas. Once it dies, i turn the ignition off, put the gear in P, restart it and its running again. I
I’ve gone to numerous shops without any luck, nobody can even identify the issue!
The battery is good, alternator too. Its not overheating or giving any other signs of trouble.
Its been hooked up to the computer with no error codes !
Does anyone have any clue on what can be causing the engine to turn off?
thanks , george
Old Dec 29, 2017 | 02:30 PM
alexanderfoti's Avatar
2013 W204 C63 AMG, 2008 W221 S65 AMG
Originally Posted by Gkuban
Hi all,
thanks , george
Hi George
I would suspect a vacuum leak would of some kind. Check all the vacuum pipes and brake booster line.
If you have access to diagnostics, check your long term fuel trims as well.
Old Jan 21, 2018 | 01:16 AM
Gkuban's Avatar
2000 G500
Originally Posted by alexanderfoti
Hi George
hi, thanks for the above suggestions but now it turns out the ECU is bust ( part # 0265452032 )
does anyone have an idea where to find this ?
will i be able to find an ECU for such an oldie ?
thanks,
george
Old May 1, 2018 | 03:43 AM
Gkuban's Avatar
2000 G500
thanks,
george
hi all, am still struggling. need an ECU .. any leads to follow ?
thanks
Old May 1, 2018 | 09:12 AM
Holson's Avatar
18 G550, 24 EQB3504M
thanks
i am fairly certain you can buy new from a Benz dealership. However try eBay or ping Guido at off-road-world.com. He also frequents the other G Class forum clubgwagen.com, quite a lot more technical activities there
Old May 1, 2018 | 10:43 AM
NYCBenz's Avatar
6x6 | 4x4
Hi George -
Contact Silber Arrows, they are an independent Mercedes Service Center in Dubai.
They took amazing care of a Japanese Spec E Wagon I had while I was living there.
http://www.silberarrows.com/contact
+971 (0)4 380 5515
Ask to speak with Phiip. Tell him Justin from NYC gave you his info. He will take extremely good care of you, and your Baby G!
