g550 2015 flashed ecu
Hey guys ! I bought a g550 2015 with no start I have been working on it for a year now. I was able to replace all components in srs cleared with no errors(not sure if it still has crash signal). Im with a huge problem now. I had no start on my g wagon ezs marked ism no me yes. I went to das and tried to see in the coding if the transmission was activated. I go into the coding section on explizite it told me I had the wrong coding so I started selecting from the options HUGE MISTAKE!. ezs marks no now on ME Then I get like 9 errors on ME. I tried to flashed the me97 with vediamo files, it flashes turns on the fan like a turbine I had to disconnect it. Finished flashing successfull. Im not sure if I am loaoding the correct files, since I did another HUGE MISTAKE on not creating a backup first. I have tried to go into das to write the plant data it writes it successful but im not getting the ecu to communicate with the network. I might be missing some steps maybe? I get control unit adaptations download has to be entered manually but I have no idea what to put on dtc, scn, fin hex values. Does anyone here has the correct files for this ecu. Or if you can point me out on the right directions if im missing a step. Let me knows what info or pix I can supply to help solve the problem.
