Rear Brakes binding - 2002 G500
Old Mar 24, 2018 | 04:29 PM
grane's Avatar
GLK350, SL63 AMG
I don't drive my G500 /149kMiles very much since I work from home. The truck is always garaged. Problem: The rear brakes were definitely worn more than the fronts. This is counter-intuitive. Also, when I went around corners it seemed as if there was a "moaning" sound coming from the rears.
I had all four rotors and pads replaced with a stop-tech kit that one can find on Amazon. Lighter and more corrosion free than stock MB parts. Fluid was changed and the slides were lubricated. New wear sensors were installed. The pistons in the calipers are all fine.
A few months after, I found that the rear brakes are always engaging and the fronts don't even get warm. I went to three different techs. (of course 2 wanted to start swapping out parts.) One said that I have to drive the car in reverse for some distance occasionally and then apply the brakes. I've been doing this and the procedure seems to be correcting the problem. The front brakes are definitely getting warmer and closer to the rears in temp. He explained, since the car sits, that the AWD system needs to have the fluid in the various differentials circulated to even out the pressures in the differentials for the ABS and the proportioning system. (Do not confuse this with the diff locking system.)
I'm backing the car up for 100 yds or so several times in a safe place whenever I take out the vehicle. The problem is getting gradually better.
Anyone else have this problem? Any ideas about how to fix the problem?
