G55 Pulls left only when accelerating
I have a 2011 G55 with steering issue, my car pulls to the left only under acceleration and when I let go the throttle paddle to cruise car steering will straiten and drives norma, I did wheel/tire alignment and while doing that I found that the steering damper had a missing bushing, I changed it with a new one and I changed the engine and transmission mounts as well cause it was time to change them, but nothing fixed the pulling left issue, I also checked all my front and rear end bushings all in great shape, I also have my front diff checked and the garage told me it has a very minimal grinding sound but they also told me it has nothing to do with the car steers to the left when accelerating.
Please guys, I really need some help, where to look at and whats the cause of this issue?
Regards
Fahad
Regards
Fahad
The other possibility is the Panhard rod bushings. If these are worn, the axle can translate sideways, thus creating an improper thrust angle.
You might want to take it to a good alignment shop and have them check the toe on both the front and rear axles and then calculate the thrust angle. The answer should be zero for all three. They might complain that the rear is not adjustable, but measure it anyway. If the rear toe or the thrust angle is not zero, check/replace the bushings. Do the frame ones first as they most often are the issue.
