Spare Tire Reverse Mount
Old Nov 16, 2018 | 03:17 PM
JACWAGN's Avatar
2014 G550
Off road tires won't fit under the spare tire cover? Want to show off your rims to the drivers behind you? Get the Spare Tire Reverse Mount, flip that wheel around, and your problems are solved! A rugged outdoor look that holds those big beefy off road tires!
Easy to bolt on in a few minutes. Comes with two sets of door spacers and bolts to fit various wheel sizes. The short door spacers are for 2002 and newer models with 18" wheels. The long spacers are for pre-2000 models and any wheel 19" or larger.
G Wagons with 19" and larger wheels, the factory spare is 18" and will use the short spacers unless you purchase a matching spare wheel.
Includes 5 OEM wheel bolts. Powder coated finish is durable and long lasting. Laser cut 3/16" steel base plate and 3/8" wheel flange with precision welded nuts. The center tube is high strength DOM steel and is hub centric to the wheel for easy installation.
Caution: 2019 model now features camera below the tire mount. This mount in conjunction with a larger than stock tire may result in blocking and damaging your reverse camera.
Available on our website: https://jackwagonoverlanding.com/pro...-reverse-mount
Old Nov 18, 2018 | 03:09 PM
Sarlox's Avatar
2014 ML63 2015 G550 2016 G550 & (2) 2019 G550s
Looks great JW
