Seat comfort controls
Old Feb 1, 2019 | 11:15 PM
Rebelbac's Avatar
G550
the right side drivers seat switches of my 2012 G550 that control the lumbar and other parts of the seat stopped working. Not sure what that part of the seat or those switches would be called to check the fuses. The passenger seats switches aren’t working as well. Could someone help point me to the right fuse to check or if you could help me diagnose it I’d be grateful. It seemed to have started when I had my head unit replaced...
Old Feb 3, 2019 | 05:11 PM
Rebelbac's Avatar
G550
Old Feb 6, 2019 | 06:58 PM
Limey Hooligan's Avatar
2012 G550 - Capri Blue Metallic
The seat contour controls not working is a very common problem. It's a pneumatic system with airbags in the seats and an air pump under the passenger seat (I believe). So either both seats work, or neither works. Most likely the pump or the pump fuse is burned out, which happens when the system springs a leak and the pump is on all the time trying to maintain pressure. Either the pump or the pump fuse needs to be replaced.
Old Feb 10, 2019 | 06:52 PM
Rebelbac's Avatar
G550
Thanks for the responses. I’m wondering if the installers who put in my aftermarket stereo screwed it up. My SRS light wouldn’t go off and my local repair shop discovered that the air bag wire in the column where the driver seat belt is was disconnected. Maybe they disconnected some other wires?
Old Feb 10, 2019 | 09:23 PM
Sarlox's Avatar
2014 ML63 2015 G550 2016 G550 & (2) 2019 G550s
Seems like the seating functions, whether is lights or actual functionality is a common issue with these new models
Old Oct 3, 2019 | 07:30 AM
Ghulmiyyah's Avatar
2015 G500
Hello
I have an issue with my passenger seat where i can hear the pump working for a couple of seconds every minute seems like there is an air leak and its trying to regulate itself
does anyone know a solution
im thinking of disconnecting it because i never use it
