Question for 2019 G-Wagen Owner's - Cabin "Whistling"
Old Mar 4, 2019 | 11:13 AM
fabbrisd1's Avatar
A gaggle of MB's
Quick question for 2019 G-Wagen owner's - does your cabin "whistle" when Climate Control is on ?
The 2019 G-Wagen has water-tight door seals - and two small exterior vents at the back D-Pillar.
The customer issue we have diagnosed is at highway speed - with Climate Control on normal mode - those two rear vents produce a low volume but consistent "whistling noise" inside the cabin.
Question is - for other G-Wagen owners - do you have this "cabin whistling too" ?
Inquiring minds need to know to input upstream to MB Germany - let me know.
Keep the beat !
Old Mar 4, 2019 | 02:46 PM
haa's Avatar
haa
Keep the beat !
Don't have it on my Edition 1 G63
Old Mar 4, 2019 | 03:29 PM
Crfiv's Avatar
2021 G63, 2020 Tesla Model S, 2020 Ford Raptor
Keep the beat !
People have definitely commented about it in a few threads but the forum is hard to search - here are a few and hopefully others will chime in here if they've had any issues (or have figured out how to successfully fix them):
https://mbworld.org/forums/new-membe...2019-g550.html
And quite a few mentions on this thread:
https://mbworld.org/forums/g-class-w...t-working.html
Old Mar 4, 2019 | 06:49 PM
pateljb's Avatar
2009 S550 4Matic 2009 GL 550 2009 AM DBS
Keep the beat !
We got our2019 G550 in November and that's the only negative we have about this version of the G. We've only noticed it at full fan speed of 7, so to combat it we turn fan speed down to 5 or 6 and the whistling goes away.
Old Mar 5, 2019 | 01:47 PM
fabbrisd1's Avatar
A gaggle of MB's
Got the reply from Germany today - and they issued a Advisory TSB.
Germany's short term recommendation is (3) parts: (1) advise customer to turn Climate Control fan to 4 or lower - (2) remove rear door panels and remove two "foam channel blocks" each panel - (3) Front door inner seals - trim approx 3mm "gap" - items #2 and #3 deigned to let cabin air "breath" into door panels .
Germany has under long term research/advise future solution... no timeframe.
Old Mar 5, 2019 | 05:24 PM
morley8000's Avatar
2017 S550 Cabriolet
Our 550 whistles from the front passenger air vent. It's maddening! ! Our dealer is still waiting for a fix. We picked it up in November. If you crack the passenger window just minutely it disappears..... Frustrating
Old Mar 6, 2019 | 07:37 PM
emmutnyc's Avatar
g550
Yes! Mine is the driver's side air vent. Our dealer says they are working on it, but it has been 3-4 months now and no solutions.
Old Mar 7, 2019 | 10:13 PM
zevrosenthal's Avatar
2010 e
I haven’t noticed a whistle with my G550 though 99% of the time I leave climate control on auto and it almost never runs the fan on high.
inwas, however, wondering what purpose the exterior vents on the back d pillar serve. When the car is running, there is a definite flow of air from the vents that seems to be powered by some fan
Old Mar 7, 2019 | 11:09 PM
dunderhi's Avatar
19 X3, 24 Tacoma Trailhunter, 25 CLE53
I haven’t noticed a whistling sound from any the vents, but if I open a window just a tiny bit there’as serious whistle from the air blowing past the window. It makes me think the G is pretty close to airtight.
Old Mar 8, 2019 | 12:02 AM
amg_ghost's Avatar
AMG GTR
Mine hisses too, (edition 1)
Old Mar 8, 2019 | 11:47 AM
fabbrisd1's Avatar
A gaggle of MB's
From what I was told - technically the cabin seals were designed to seal out water (no a submarine - think of fording a stream) - and as a result not enough "air bleeding" when at highway speed with Climate Control On - or as some have reported - with Climate Control Fan high - and also as separate deal if side window is just cracked a small bit with sunroof closed you get buffeting/whistle.
Thanks for the feedback - when Germany gets back to me on this lower priority "whistle" I will post back to the forum - keep the beat !
Old Mar 9, 2019 | 06:45 PM
Sarlox's Avatar
2014 ML63 2015 G550 2016 G550 & (2) 2019 G550s
My wife's 2019 G550 whistles when the climate control is on. She says, "it's damn annoying"
Old Mar 10, 2019 | 02:05 PM
M1M2M3's Avatar
Mercedes
mine whistles from passenger side randomly also my ears pop whenever I open the windows. Even if the car is not moving after I have been driving a while. The vents on the C pillar I think are supposed to be regulating cabin pressure, idk...
Old Mar 14, 2019 | 06:36 AM
mpshah's Avatar
2019 G500
I can confirm this issue on my G 500 2019. The whistle starts as soon as I increase the fan speed to 5 and above.
Old Nov 21, 2019 | 01:10 PM
drew138's Avatar
993 TT
Saw this today and had to laugh, go to 9.55 of the video....
Can confirm this is an issue on my 2019 G63
Old Feb 9, 2020 | 11:45 PM
Festertester's Avatar
‘13 911-4S, ‘21 CTR, '22 GT4, ‘19 G63
@fabbrisd1 : any news from Germany? The whistle is very annoying at hvac speeds 3 and above ...
Old Feb 10, 2020 | 09:50 AM
Surge's Avatar
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
I don’t have any whistling on my 2019 G550 (August production). This type of thing would drive me crazy, so I’m glad it’s not there. I’m sure MB will fix it soon.
Old Feb 10, 2020 | 03:55 PM
obbob's Avatar
I notice whistling on mine as well at speeds above 70mph
Old Feb 12, 2020 | 02:23 AM
Jacek Siewiera's Avatar
G500
Does anyone have solved the problem?
I have this same whistle in my G500 on the highway speed. especially when there is a side wind presence.
Its irritating. My dealer told me that they cuted a little a gasket inside of the right-side front ventilator but it did not helped much.
I see that latetst post is from april 2019 so quite long ago.
Old Feb 12, 2020 | 03:08 AM
nope I’m wondering the same. Next service I’ll take it again. They did the same on mine but didn’t resolve the issue I really hope MB has a fix
Old Feb 15, 2020 | 07:51 PM
Condor Man's Avatar
G63, SLS, CLK63 BS, GLE63s, 812GTS, 296GTB, 599GTB, 575M, 992Touring, 356Speedster
My 2019 550 which was delivered in Oct 19 never had the noise and now it has developed the noise in the last 3 weeks, this only occurs when the vehicle is driven over 25 mph.
Initially we thought it was from the door surround however the guys at MB taped up the door and it is still making the noise.
Old Feb 15, 2020 | 09:23 PM
Surge's Avatar
This is a long shot, but check the gaps around the side windows — that is, the rubber trim around the windows. Tape the window edges if need be.
I noticed a different type of whistling, like a kettle boiling, after my door panel was removed to fix a damaged lock. The tech left a gap between the bottom of the window and the rubber/felt seal, and it now whistles. Mind you, this is on the inside of the car, and my whistling varies with the HVAC fan speed, for some reason. I think the bottom line is the window seals may be the culprit for you too - probably on the outside.
Old May 1, 2020 | 01:28 AM
Condor Man's Avatar
So the guys at Beverly Hills took 2.5 weeks and they finally fixed the noise.
It turned out to be the driver’s side mirror was not fitting correctly.
Unbelievable!!!
I can 100% report that the noise has gone!
Old May 1, 2020 | 02:34 AM
Unbelievable!!!
oh man, really?
my driver side mirror continues to gently vibrate at speeds over 60mph and that’s after they replaced it once. Did your mirror frame slightly vibrate before and how’s it now? I continue to have this whistle noise issue
Old May 1, 2020 | 07:27 AM
Surge's Avatar
Originally Posted by Festertester
oh man, really?
My driver’s side mirror vibrates gently at highway speeds too, but I don’t have the noise. I did have a whistle noise, my daughter called it a boiling kettle noise, when one of the rear door panels had been removed to fix a lock. The seal between the window and the door, on the inside of the car, had a gap. Air was getting through that gap and causing the noise when the HVAC was on. If your noise goes away with the fan off, this could be the cause.
