W463 G500 Front Differential Rebuild / Replacement
Had some nasty noises emanating from the front diff, so I got a mechanic to take a look. It appears the ring and pinion have some significant wear and need replacement. I've been quoted anywhere between 5 and 10k to replace / repair it.
Does anybody have recommendations or experience with a diff rebuild in one of these beasts?
Cheers
The $5K range for all of that would be reasonable IMHO, $10K is on the rich side.
Another option would be to find a used axle assembly, but its condition would be unknown - you may end up with more problems than you solve. Also, I believe that the '08 and later axle assembly is different than the '02-07 ones, potentially making it harder to find one.
Just found this entire front assembly on EBay
$5k shipped from portland.
There's no way this is a $5k labor job. If I needed to I could knock this out in a weekend in my driveway. With a lift it would prob be 6-7hrs max of labor.
Even at $200/hr that's only $1200.
I'd also call around re: servicing.
Here's a gear assembly, so I'd only assume you can rebuild it and save on replacing good parts.
https://www.ebay.com/i/254415208696?...0aAmAyEALw_wcB
Keep us posted and good luck!
-Ian
-Ian
I still haven't had any leads, but I've been recommended a shop down in Portland that specialises in them so I will update here accordingly.
Cheers
