Cargo mat missing?
463-684-43-00-9H42
I still need to find a cargo cover to go over the "extremely practical" off-white carpet in the cargo area of mine! :\
And is the mat: https://www.mboemparts.com/oem-parts...ack-4638140000 (goes over the above liner)
Actually Bob has the part numbers and pricing reversed.
The picture is very misleading and should be reversed. The carpet #10 should be on the bottom then the liner #50 and the rubber mat #20 on top.
The liner is around $100 p/n 463-814-00-00 and has the MB Star logo. The rubber mat is $150 p/n 463-684-43-00-9H42 carries the G logo and is cut for the tie down rings.
I have the liner and it fits snugly in the cargo area. in all corners and areas. I think the rubber mat would fit nicely inside the liner if someone wanted both. I wanted and ordered the rubber mat and received the liner. I decided to keep it since it would prevent spills, mud, snow and other dirt from ruining the cargo carpet since it has turned up edges to keep any spilled liquids contained.
Because of this feature, I considered it and will not be cutting out the marked corner areas for the cargo rings. I may buy the mat later and install it inside the liner for daily use. Then I will be able to remove it for those times when just the liner is needed.
It has a more plastic feel and bend quality than rubber, but it covers the rear nicely.
Btw it arrived in a ridiculously large box, over 10 times and thick and twice as wide.
I originally ordered from https://www.mboemparts.com, but after one day they canceled the order citing lack of staffing due to pandemic/stay-at-home.
I am curious though about the rubber mat, I may try that too.
