Do 2018 and older G wheels fit on a 2020?
Old Jan 20, 2020 | 07:41 PM
rhyno's Avatar
2016 G550 - 1999 G320 SWB - 2001 G320-Cabrio
As the title says do the 2018 and older Gclass wheels fit on the brand new 2019 and 2020 models?
Old Jan 20, 2020 | 09:06 PM
pateljb's Avatar
2009 S550 4Matic 2009 GL 550 2009 AM DBS
Yes, I’ve been told that all G’s have the same bolt pattern 5x130mm so they will fit.
Old Jan 21, 2020 | 12:38 AM
Bkhko's Avatar
G63
Bolt pattern is the same but offsets are 15mm different.
with the larger G63 brakes on the 2019, I could not use my 2018 G63 wheels due to brake clearance.
Old Jan 21, 2020 | 09:14 AM
johnnyderm's Avatar
Soon: 2020 G63 Currently: 2016 GLE63 SUV + 97 F250HD, Before: 2013 G550, Range Rover Sport, 1984 CJ7
You will need Spacers 15mm plus as BKHKO said. Maybe 30's to make the look excellent.
Old Jan 21, 2020 | 08:56 PM
rhyno's Avatar
Thanks for the info!
Old Jan 22, 2020 | 01:45 AM
Venom-AMG's Avatar
21 G63, 21 GLS580, 16 GTS Ed. 1
Then do aftermarket wheels from prior generation work? They usually are 30mm offset compared to stock 50mm offset. I'm asking because someone inquired about the set I'm selling.
Old Jan 22, 2020 | 03:36 PM
LWSG550's Avatar
2019 G550
Does anyone know if the offsets are different on the 2018 and older G550s compared to the 2019 and newer G550s? One of the reasons that I wanted the G550 over the G63 was so that I could drop from the stock 19s down to 18s without brake clearance issues and make-up the extra inch with deeper treads and sidewalls. I will have garage clearance issues if I add tread to the stock 19s. It would be nice to be able to purchase some unloved 18s from the previous gen trucks rather than springing to import the black factory 18s that are offered in some non-US markets for the 2019 and newer G550s. I would prefer not to go aftermarket, and I do not like black wheels.
