Need help fixing multi-contour seats
1 To adjust the thigh cushion 2 To adjust the backrest contour in the lumbar region
3 To adjust the backrest contour in the upper back region
4 To adjust the side bolsters of the seat backrest
You can adjust the contour of the front seats individually so as to provide optimum support for your back and sides.
► Make sure that the SmartKey is in position 1 or 2 in the ignition lock.
https://fuse-box.info/mercedes-benz/...uses-and-relay
For the pump system, it only will run for like 30 seconds when the truck is first turned on. If there are any leaks in the system, the pump will automatically shut off and will not function again until you restart the car. If you remove the multi-contour seat controls, it'll be very noticeable if the pump is running or not.
