Lift options for my G63. Spring spacer?
Old Mar 5, 2020 | 06:48 AM
f80_lol's Avatar
W205 C63S
Hi guys. I have a 2015 G63. I'm thinking about doing a modest lift with some better shocks. The OEM shocks are just not good enough. I'm looking for improved ride quality, and based on what I found here, the Fox 2.0 might be a good choice? Also I decide to stick with OEM springs because aftermarket ones give the truck too much lift (40-50mm at least), and some people said that the G63 springs are stronger than the ones on G550 and most of the aftermarket ones. So with the OEM springs, is the 30mm spring spacer a good choice? That's the lowest lift I can find right now. My biggest concern is the problems caused by lifting: caster, geometry, gearing, and handling problems. Will a 30mm spring spacer does anything bad to the truck? Should I put on anything like bushings or stablizer bar? Hoping you guys could help me out! Btw I'm planning on running 285/45/R22 Gladiator A/T tires with Vorsteiner 22" wheels.
