analog TeleAide disable help
Old Aug 3, 2020 | 08:25 PM
juice21's Avatar
2002 g500
Anyone have any documentation to describe the correct disable procedure for the my old now defunct Teleaide system. I have the SOS warning on the MFD after I disconnected and tossed the old phone connector.
2002 g500
Thank you!
Old Aug 3, 2020 | 09:27 PM
Floobydust's Avatar
2018 GLE350, 2014 G550, 2000 SL500, 1980 TR8, 1995 E320 Cabriolet
You need someone with a Star SDS system (dealer or good Indie mechanic) to turn off the Teleaide warning/system, a simple and easy process. In theory, you could remove the Teleaide module, but you would need a D2B fiberoptic bypass loop (if you can even find one these days) or the audio, phone, and voice control systems will cease to function.
Old Aug 3, 2020 | 09:43 PM
juice21's Avatar
2002 g500
Luckily there one indy here in Durango with Star but I was hopeful that I might be able to give them some guidance as they said they have done this particular procedure on this vehicle before. It is a fairly intuitive process? My reading has me believe there is multiple incorrect ways to execute once you are plugged in.
Old Aug 3, 2020 | 10:15 PM
Floobydust's Avatar
My new Star system is not here yet (the old one was destroyed when the basement flooded), but try this link: http://www.mercedesmedic.com/teleaid...s-bnez-solved/ The W463 should program like the W203 from which the G "borrowed" most of its interior systems.
"Model 203, 209, 210 C CLK E Class: In Star Diagnosis:Control Units –> Information and communication –> ICM – Instrument cluster with maintenance interval display –> Troubleshooting by means of complaints or symptoms –> Messages from the emergency call system are displayed in the instrument cluster."
Old Aug 3, 2020 | 10:30 PM
juice21's Avatar
2002 g500
awesome that should be a good leg up for them to figure it out for me.
Thank you!
