G63 with no spare tire carrier?
Just picked up a 2015 G63 and was wondering if you could spec one from the factory without a spare tire carrier? It doesn't have the holes or anything. I definitely want to add the spare tire carrier but was told i would need a whole new tailgate. On the other hand if anyone likes the bare look i'm down to trade tailgates lol.
rickhoodz (10-04-2022)
2016 G63, 2013 c250, & 2021 Model Y
I believe all G wagons come with spare tire carrier. Your G has been modified to have the 3 holes covered by a body shop or swapped with a 4x4 squared rear door from G550. So the question is do you have a spare tire?
k4zi (08-04-2020)
k4zi (08-04-2020)
Hopefully there’s probably someone here in the forum that might want to swap with you to have that clean look in the rear. I had mine off for almost a year then just recently put the spare tire back on again to change it up. G/L though
Just added 3 rubber grommets
Your rear door is cleaner than this look.
This is now, still need to find a OEM wheel + rubber to match the rest of the wheels
1987 Porsche 911. 2008 G55
@HYPMODE how did you get the tire cover to stay on without the ring?
I tried on my K02's and if I really shook it, I could dislodge it.
I've kind of left that idea in the past, but curious to know how yours is staying on.
Great looking G!
Great looking G!
Great looking G!
Great looking G!
I have read that you were trying to solve this issue before, I too was trying to make it work for me. I didn’t want the ring on but only just the cover. The funny thing was... I was making it harder than it’s suppose to be, haha. I simplified it by drilling 2 holes on inner metal tube attached to the cover to matched the existing hole on spare tire mount. I used a 3” locking pin to lock it in place but attached a paracord to it so I can pull on it to take off. The hard part is getting your arm slide between the rear glass door & inside the spare tire, then inserting the locking pin the holes. It gets easier the more you do it 🥴. It’s still a temporary fix for me but works good for now. The cover is lock in place & does not move out at all. I had it on for a while now & I check regularly for any movements. So far so good! I will take pictures tomorrow to for show & tell. Lol
z168 (01-20-2022)
Thank you, your G looks great as well.
I’ll swap
