Brush Guard Lamp Mounting
Old Aug 19, 2020 | 03:17 PM
G- Ables's Avatar
2017 G 550, 2018 Jaguar F-Type 400 Sport AWD 'vert
Search didn't show anything on this... Does anyone have auxiliary lights mounted to the factory brush guard? Can I mount a couple of round Hella Rallye 4000's without something like these Agency Power clamps?
Thanks!
Old Aug 19, 2020 | 04:24 PM
almostordinary's Avatar
1987 Porsche 911. 2008 G55
Search for Limey Hooligan, he's got a nice setup
Old Aug 19, 2020 | 06:26 PM
shiann's Avatar
2005 G55K
Here's some info on Limey Hooligan's setup. Post #80 and Post #83.
There are threaded holes on the lower middle bar of the brush guard, but you will most likely need some sort of custom bracket to mount any type of light to them. The threaded holes are 14-7/8" apart and may be an M6 or M7 thread (I have not checked). I believe Limey had a shop drill through the bar and mount the lights that way.
Looking at the Hella Rallye 4000 mounting instructions, you would have to make some small bracket to mount to the lower bar, then to the lower screw thread on the lights. This would basically be the same as using those brackets you linked.
Alternatively, you can try to find a bolt that will fit through the housing to bolt directly to the lower middle bar, but that may not be possible as it looks like they include a custom square head bolt and have designed it to mount with a nut/washer from the bottom. (square head being that it can't rotate from the inside)
Old Aug 20, 2020 | 08:51 AM
G- Ables's Avatar
Thanks- this is helpful!
