Help getting the air intake grill removed.
Old Aug 21, 2020 | 10:35 PM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
Hey all,
I've noticed that the grill on the bonnet that covers the air intake has dulled quite a bit. I'd like to take it off to give it a quick coat of paint. I've looked at the bolts (or screws or tabs) and have tried to remove them - no such luck. Does anyone know what the procedure is to remove these things?
Thanks!
Grill
Underside of bonnet
Closeup of bolt
Old Aug 21, 2020 | 11:01 PM
shiann's Avatar
2005 G55K
They look like pop rivets/plastic panel clips. Push out the center cylinder part (make sure not to loose them, or buy new clips) and the outer surround part should be able to come out easy by pinching the bottom fingers and pushing out.
Old Aug 23, 2020 | 11:29 PM
Black Forest's Avatar
600SL,190E 16V, 02' G500
Or use a pick and push the centre pin up. Either way as mentioned above - don't loose them.
Old Aug 25, 2020 | 03:13 PM
JD101b's Avatar
I managed to remove seven of the pins/rivets. However, three are blocked by a long piece of metal that spans the width of the hood. Any ideas on how I may be able to reach them, or is there a way to remove the rivets from the top?
