300GD won't start
300GD won't start
Hi,
I have pulled out and cleaned (no water) all the gauges on my 300GD.
The battery it has is good, already worked in the G, and charged to 13.8 V.
I have put everything back in place, according to photos I took. Two wires are not attached, a blue with red stripe and insulation on connector, and a ground wire. They are attached together (not connected) with a bit of tape.
When I try to start:
Put the key in lot;
Turn the key to position before starting; big noise, tachometer goes to 4000rpm on its own;
Turn the key to start; noise stops, tachometer stops. Clicks one time, won't start.
Any help will be MUCH appreciated. Electrical problems are the ones that I hate the most...
Put the key in lot;
They are the same kind of wires that go to the instruments. They are taped to stay alongside each other, but not connected to each other nor to anything. The big noise is coming from the glow plug relay. This morning I tried one more time to start it, noise seemed gone and glow plug light was on but battery went too weak again. The problem may have solved itself, but I still need to check.
Battery tested good. My mechanic friend thought what if we changed it anyways, and problem solved. These things are weird. Battery put out good voltage, good amps and all.
Really strange battery behavior and odd the tester didn't identify it, but great to know the solution was simple. I've never owned a "d" - maybe the engine pre-heating cycle causes a different battery aging effect where volts and amps can measure OK, but its energy capacity deteriorates to where there's just not enough juice to get the job done.
