Thought I would do a short review of hitch spare tire carrier, RIGD Ultra Swing Multi-fit. As advertised by the manufacturer, the fit is amazing and there is zero wobble. The install was simple, about 30-45 mins with common tools. Since this was their newest model, it came with the new handle for the tension clamp and also a license plate relocation kit. As you can see from the pics below, it is able to carry up 35 inch tire ( this model, their mega swing model can carry up to 37 inch tire I believe). This kit will be perfect for those who worry about the extra plus size tire and wheel possibly over stressing the rear door mount ( factory). Also for those who desire to carry extra stuff like I do (see pics). Here are my pros and cons:
Pros:
1 - Fit and finish is top notch. The dura coating and parts used are top notch.
2 - Zero wobble.
3 - License plate relocation kit.
4 - Heavy duty, easily carry up to 35 inch tire, max trax, rotopax and trasharoo…. and more.
5 - the tire sits lower than factory, better rear view.
6 - the carrier opens away from the rear door and gives plenty room. Also the hitch beam serves as a good solid stepping spot to reach the RTT. I am short so this is a big deal.
7 - Double safety pin design. No way for this to come unintentionally loose with the safety pin in place.
Cons:
1 - Can’t get to the back storage unless you open the tire hitch each time.
2 - the spare tire sits lower than before, it “could” be an issue on departure angle for some?
3 - the spare tire sits lower than before so it trips the backup sensor.
4 - Pricing. Not a cheap mod but I am happy with it so far.
Man, you are getting equipped out to the max...
I think you picked about the only solution available for an alternative rear tire carrier. I came close to fitting a rear bumper tire and fuel carrier, but found out from some reliable sources that the G rear bumper mounts weren't designed to carry that kind of load. So I think you've done about the only thing possible for something like this without major frame welding activity.
Yes, the wagon is gaining some weight and now I am bit worried about her GVW. In addition she is one thirsty gal so I need some additional fuel on hand to reduce my low fuel anxiety. I tried the roof top rack with rotopax but my vertically challenge self found that to be not workable nor safe. I also tried the spare tire mount with the extra fuel but didn’t feel good about the factory door mount taking all that weight. So here I am for now. I did some eastern OR exploration (Steens Mountain and Alvord desert) where fuel can be very challenging to find. So, for now I think I am just waiting for ORC rear sway bar kit to remedy the rear “happiness” and I think I am good to go. For now……
