Sprin spacers
Old Sep 24, 2021 | 04:28 PM
Gene Gorman's Avatar
05 SL55, 10 C63, 12 SLK3, 20 S560, 08Bentley GT Speed, 16 Aston Martin Vanquish
Sprin spacers
How hard is it to install 40mm spring spacers on a G55?
Any instructions would be greatly appreciated.
Thanks Gene
Old Sep 26, 2021 | 12:07 AM
shiann's Avatar
2005 G55K
It's not that difficult if you're use to working on truck-like suspension. Air tools are, in my opinion, a must. You'll need heavy duty spring compressors, heavy duty jacks and jack stands, as well as a full assortment of 1/2 sockets and breaker bars. Also many larger wrenches. If you have a lift even better as lots of time is spent just getting the axles off the ground and at full travel.
If I were to add spring spacers to my G55 (after already having swapped out to G63 springs and Fox shocks), it would probably take 4ish hours for all corners, give or take. If I was doing it the first time, it would probably take 3-4 hours per axle.
Old Sep 26, 2021 | 12:47 AM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
Unless you have experience and tools, get a shop to do it.
