Driver and passenger seat not moving in any direction
Old Nov 5, 2021 | 10:41 AM
PeriodCorrect's Avatar
2011 G550
2011 G550. Noticed today that none of the seat controls for either driver nor passenger are working. There’s no sound, no attempt at moving, nothing. What could cause this? Not even the headrest adjustment works.
Interestingly enough the air bladders do work.
My only thought is wondering if my facelift 2013 mirrors that were installed with a resistor in each door panel has caused heat damage to the seat switches or wiring? The electrician put the resistors (in gold) near this area:
thoughts? Windows and door locks operate fine.
Old Nov 5, 2021 | 11:39 AM
YCHU's Avatar
2008 S550, 2004 G500, 2020 Cayenne
I'd first check the fuse
Old Nov 5, 2021 | 12:14 PM
2011 G550
Thank you!
Fuse was good but found the electrician forgot to clip the seat motor cable back in. Easy fix!
