18 g63 22 inch wheels and 33s
Old Jan 1, 2023 | 11:22 AM
Btendon1980's Avatar
2018 g63
Just purchased a 2018 G63 with factory 20 inch wheels on summer tires. I want to purchase aftermarket 22 inch wheels and run all terrain tires. I have searched the forum and cant find the exact info. Does anyone know what wheel width and offset i would need? What size tire works best with no rubbing or a stuffed look with this setup? Thanks for any help
Old Jan 2, 2023 | 11:19 AM
The Butcher's Avatar
G63, G65
22x10.5, +35 with 33x12.50r22 works, but it might rub a touch at full lock.
Old Jan 2, 2023 | 11:55 AM
2018 g63
Would a 10 in wheel take care of rubbing. The height should not be a issue just width correct?
Old Jan 2, 2023 | 11:00 PM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
20x10.5 Et25 is what the spec was on my Forgestar for my 63 - 305's fit perfectly.... but I'm running 325's now with minimal rubbing ( different rims and using 30mm spacers for time being - they are a 18x9 et 25 with the 30mm spacer effective -5 offset)
The forgestars were light and held up well - and removed need for the heavy spacers ( 14lbs for a full set plus lugs !) - they'll build 22's if you want some rubber band stretchers...
offset is the issue - you need to get tire out to change scrub radius.... a 40-50mm spring spacer is the best way to ensure full clearance, without running into the challenges of quirks the 4" kits can have....
pics of the G ?
E
Old Jan 3, 2023 | 11:15 AM
G63, G65
As @Texas E63 said, the offset will be crucial for rub or no rub. A 10" wide wheel might help if the offset remains the same, or goes more positive (effectively bringing the outer edge of the wheel more towards the center). Or, run a shorter tire (BFG are typically short for their listed sizes).
