View Poll Results: Would you put those brakes on?
Yes they are worth it
1
100.00%
No, I think this car is already equipped with good enough brakes.
0
0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Carbon-ceramic brakes for Mercedes Benz AMG G63 Brabus 700 Adventure XLP 4x4
Mercedes-Benz AMG G63 Brabus 700 Adventure XLP 4x4
Mercedes-Benz AMG G63 Brabus 700 Adventure XLP 4x4 is equipped with a 4.0 V8 Biturbo engine, its power is 700 HP with a torque of 950 Nm. A powerful enough car and with its weight of 3515 kg, This car is a real monster on the road and not only.
The 4x4 model has received a major improvement in the chassis, the wheelbase of the cars has been increased by almost half a meter, and the overall length is 5,310 mm, which is 689 mm more than the standard model of the G series.
Thanks to the Brabus modification, it was possible to increase the ground clearance to an impressive 490 mm, which automatically makes this car ideal for off-roading.
The car also has impressive R22 inch wheels.
But let's talk about the braking system of this car.
In stock, it is equipped with standard AMG brakes.
These brakes are not only heavy due to the cast iron brake discs, but under the weight of the car there is a big risk of burning the brake discs if you decide to test this car in a more aggressive driving environment.
I found a solution that will help avoid all these problems.
It's a carbon ceramic brake system.
It can withstand temperatures up to 1130 degrees Fahrenheit. And besides, all components are many times lighter than the stock brake system, which will greatly lighten your already heavy SUV.
Let's go through the components of this system.
Front axle:
- Carbon-ceramic brake rotors in size 440x40 mm
- Front 6-pot Brembo calipers
- Front carbon-ceramic brake pad set
- Specialy designed aluminum caliper adapters
- Brake disc dust shields
- Aluminum/titanium brake disc hats
- Goodridge brake lines
Rear axle:
- Carbon-ceramic brake rotors in size 410x32 mm
- Rear 4-pot Brembo calipers
- Carbon-ceramic brake pad set
- Brembo additional parking brake calipers
- Parking brake caliper pads
After installing such a system, you will not only improve the braking performance, but you will feel that your car has become a friend, and you will get a completely new driving experience. In addition, quite many believe that there is a high risk of damaging carbon-ceramic brake discs while riding off-road, but this is not the case with a material so strong that it can withstand even the harshest conditions.
If you have any questions, feel free to leave a comment, and I will try to answer everything.
Front axle:
Rear axle:
