2005 g55 amg brake issue
no issues found during the pad install but after the fact the pedal was very soft. After pressing 2 times the pedal would go back to firm, but if held pressure the pedal would sink to the floor board. Brakes still have enough pressure to stop but definitely a very very soft pedal.
I bled the brakes today and no air was found.
my concern is when I compressed the pistons and shoved fluid back into the master did it cause an internal seal failure and I need a new master.
Or do I just somehow need to engage the abs pump a few times for some reason to reset everything? Is there a simple way to engage the pump without some emergency stops?
thanks in advance
