Code P0455 Check engine/fuel cap open
Old Mar 26, 2023 | 11:25 AM
Uplift's Avatar
2003 G55-wagon AMG
I have done the following:
Change the fuel cap and nothing.
Installed a new Charcoal canister and nothing
Installed purge valve and nothing
It passed the smoke test and the codes come back after a few miles. I checked the fuel neck and no smell or leaks.
Any advice would be helpful.
Old Mar 27, 2023 | 04:33 PM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
The same problem happens with my G550. I've found that waiting for the problem to go away is typically the best solution
Old Oct 2, 2024 | 04:17 PM
Edmundo Amado's Avatar
2014 ML 450
Check this post, it might help:
https://mbworld.org/forums/g-class-w...dvice-cel.html
Old Oct 28, 2024 | 10:20 PM
Tmullan1's Avatar
E350
Any chance you mind sharing your setup for wheels? And did you need a lift?
Running into similar issue, just did a few of the same… would yours intermittently go on/off?
