2017 G63 - strange steering noise at standstill + oil leak - help!
Just noticed a strange noise coming from the front axle / steering when the car is static - moving the steering wheel slightly in either direction, very noticeable in the video linked below - the wheels remain straight, so minimal angle. Came out of nowhere, car serviced every year as per schedule. Drives normally, too - not feeling any change to steering input required.
https://youtu.be/wLpbg8WomZM?si=N9APDTLXj1w7GZbj
At the same time, I noticed what looks like oil dripping and hitting the exhaust manifold and then down on the frame. This is the passenger side - the vehicle is RHD.
Could not see from the engine bay where oil could be coming from. Will get a camera and try to have a look later today when the car is cold.
Would very much appreciate your guidance as to what could cause these two issues before I have to go to the dealer.
Thank you very much!
P.S. I also posted in the G55 section earlier, but realise there is much more activity here, hope this is ok!
