Rear Tailgate door light sensor
Right now, when I unlock the truck and open the rear tailgate, it auto locks itself back while the door is open. Doesn't do that for the front 4 doors.
The light also doesn't turn on in the rear. I can turn it on manually when I'm in the car through the sunroof control panel, but that's about it.
Is there a way for the light to turn on when the door opens, and doesn't auto lock the doors?
Not sure about the door locking but there should be a 3-way switch on either side of the top. I discovered how mine worked when changing to LED bulbs to brighten up the area at night when needed. Both of mine have 3-way switches... On with door open - OFF - On with switch only. Keeping the switch in the center and they will never light. Move both one way and they will both light with door open.... Move both the other way and they will both light and STAY ON!
Sorry about that. I have a 2010 G55.
I tried a few things today. When I put the button in the middle, and open the front doors, only the front lights turn on. When I open the rear doors, only the rear lights turn on. I guess that's a good thing. I'm just used to all lights turning on when you open any door. When I open the rear tailgate, nothing turns on.
When i push the button to the left, with doors open or closed, both front and rear lights turn on (not tailgate lights).
When I push the button to the right, nothing turns on no matter what you do.
I have an additional button on the top just for the tailgate light. But it only turns on when the ignition is on. If Ignition is off, the tailgate button does nothing.
No matter what option I choose or do, the tailgate light doesn't turn on when the tailgate door is open.
