Where does the reverse lamp wiring run?
Old Feb 26, 2024 | 01:01 PM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
I'm replacing the stock flares on my G with wider G63 flares. After replacing the fender liner on my rear passenger wheel well, I'm experiencing intermittent loss of the reverse light. For the first few days the light worked, but after that I've lost it almost entirely.
I got under the G and it seems that the wiring moves away from the fender flare in question. There does not appear to be any wiring running near the liner so I don't think I've pulled it out but the timing seems to indicate that I inadvertently damaged the wire during the install process.
Any thoughts?
