G300TD W463 1997 Towbar, Trailer hitch with 10cm, 4" drop, 3500kg
Old Apr 25, 2024 | 01:35 AM
TBM's Avatar
TBM
G300TD W463 1997
Question G300TD W463 1997 Towbar, Trailer hitch with 10cm, 4" drop, 3500kg
Hi!
My G wagon is a G300TD W463 1997 is upgraded with ORC springs +40mm, Hutchinson rims and 285/75x16, that looks cool (I think), but my trailer hitch (standard Oris D 96/4 3500kg) is now ca10cm too high above ground...
I need to replace the trailer hitch with a TÜV approved trailer hitch that drops the ball/coupling ca10cm or 4".
I would prefer to have a "square mount" so I can unplug the ball if needed in an easy way...
My rear bumper is in one piece (not split)...
I have tried some googling, but no luck so far. Any tips much appreciated!!
Cheers, Tom :-)
Old Apr 25, 2024 | 09:36 AM
streborx's Avatar
Top Answer: 1
G550
Try curtmfg.com. If your current hitch ball is not removable (does not have a square receiver and pin), the complete frame hitch assembly will likely need replacing.
Old Apr 25, 2024 | 12:32 PM
TBM's Avatar
TBM
G300TD W463 1997
Thanks for your tip!
My current hitch ball is fixed.
I just searched the Curt site and found only 2250kg trailer hitch (2002 model G500), not anything before that...
Hmm, still looking...
Old Apr 28, 2024 | 02:03 PM
TBM's Avatar
TBM
G300TD W463 1997
Nobody has or can recommend a 3500kg (7800lbs) trailer hitch that can be adjusted down 10cm/4" that fits W463?
