P0305 engine code, cylinder 5 misfire detected
So I had my CEL come on, with my G63. Car was running completely normal. No hesitation, no rough idle, no poor MPGs, no issues driving at all. I got home and checked it with my scanner, P0305, “cylinder 5 misfire detected”. I cleared the code and went about my day. I do notice that everytime I start my car, the RPMs sit at 1200, even when the engines warm, then when I put it in gear the RPMs drop down to normal idling, like 600. If I turn off the car and turn it back on, the same RPM behavior?
A week later the light came on again, and the exact same code, again no driving issues. Everything I researched online recommends swapping the coil with another, to see if the code changes to that swapped cylinder, meaning a bad coil. I don’t think it’s bad coil, mainly because of no bad coil symptoms. Plus the spark plugs were changed about a year ago. Other possibles is a bad injector, or vacuum leak?
Before I take it into the dealership and pay an arm and leg for diagnostic, has anyone had the same issue? And what was the fix?
Any advices is greatly appreciated. Thanks!
