Time to replace the brake pads and possibly rotors.
I’m debating if i should change my rotors as well. My rotors have some life left to them, and it also looks like most recommend ebc rotors as well, it damn, the rear is close to $1k for the pair and fronts are around $800 for the pair. So just rotors alone. Would be about $1800.
pads def seem like a better choice to start first.
wanted to see if anyone else had any opinions?
thanks
On our last 2017, I was able to replace pads without rotors the first time, but the 2nd round, it was pads & rotors. I went with OE rotors, as the only place I could find them online was $20/ea more than the dealer. For pads , I went with Hawk because I had a connection at the time. EBC Yellow Stuff are good pads for hard use or heavier vehicles like these; they'll dust less than OE also.
There are other good options, Pagid or Zimmerman
As for the pads, Brembo, Jurid, Bendix are good choices
Shouldn't cost more than $250-$300 USD delivered. Playing $1000, $1800 is absurd. Nothing special about replacing G55 brakes
- replaced rotors with r1 concepts drilled and slotted rotors (WBPN2-40065) - lowest price i found:
- replaced brake pads with ebc yellow
- most important: upgraded to stainless steel braided brake lines
