Rear lighting Wiring 2005 G55K
Thank you!
Which color wires go to which tabs? Thanks!
I could get a multimeter and try... could you please explain this process in a little more detail? I'm just not quite following based on your description; sorry.
On the headlight harness side:
Brown = Ground
Black = Brake Light
Grey/Red = Tail Running Light
Green/Black (or is it Black/Green?) = Turn Signal
On the replacement assembly, measure the continuity between each connector tab and the contact at the bottom of each light bulb socket. Set the voltmeter switch to 200 ohms resistance and connect the black lead to one of the tabs, and connect the red lead to each of the bulb socket contacts to see which one reads 0 ohms on the voltmeter. When a contact to bulb socket reads 0 ohms, that is the tab that connects to that socket. Then connect the wires identified above with the corresponding light tab. The ground (common) connector tab is the one that reads 0 ohms to all 3 light bulb metal bases.
