G550 rear camera stopped working
Subscribe
Sep 29, 2025 | 04:28 PM
Hello to all, new member here. I have 2015 G550, made a mistake, disconnected the main battery to connect trickle charger to auxiliary battery and did not use battery charger to keep electronics from shutting down.
After the battery reconnect my rear view camera is all dark. I am guessing may be a fuse issue but can not figure out where the rear camera fuse located. Google shows under the passenger seat, but the fuse manual does not have rear camera fuse listed at all.
I am in need of your help. Thank you.
Reply 0
Sep 29, 2025 | 05:18 PM
Try a hard reset of your COMAND screen first. Hold the power button until it reboots. If that fails, check for a blown fuse in the rear fuse panel, located in the right side of your cargo area.
Reply 1
Oct 3, 2025 | 08:49 PM
Thanks for the reply. Will try and will let you know.
Reply 0
Oct 12, 2025 | 05:54 PM
Well, unfortunately reset did nott do anything and also there is no fuse panel on the Right side of the trunk. There is one on the left side but there is no telling which one is for the rear camera. Any one else have a clue where the rear camera fuse is for 2015 G550?
Reply 0
Oct 19, 2025 | 11:37 AM
Found possible fuse (5amp) if is correct (trunk left side), after viewing few diagrams of fuses. Checked, replaced, but no help.
Reply 0
Oct 24, 2025 | 08:50 PM
Any other solutions?
Reply 0
Subscribe
Currently Active Users (1)
