W463 Rear Door / Hatch Adjustment
Remove the interior trim panel to access the hinge bolts. Loosen them slightly to adjust the hatch position up or down, side to side. Check the striker plate on the body for wear, as that can also cause closing issues. A little adjustment often makes a big difference.
Be ready to have a jack or someone strong to hold the door from falling to its lowest position as it will fall since it is so heavy. I used a floor jack with a stack of wood a cushion on the bottom edge of the door. Then before loosening anything, I marked the bolts/hinge on the inside where they were so it would be easy to adjust/position them when tightening. I used tape. The bolts have adjustment up/down, and in/out.
Also check the striker plate/guide that it is aligned with the mating features on the door. This can easily push the entire door up and down when you close it.
