1017 G63 oil filter housing replacement
Old Apr 26, 2026 | 11:15 PM
JPLEE84's Avatar
2017 G63
https://mbworld.org/forums/g-class-w460-w461-w463/880419-w463-oil-filter-housing-cam-magnet-leak-howto.htmlI’m glad I found the posting above. The YouTube video included there is excellent—I’ve watched it multiple times and it explains the process very well.
This past weekend I attempted to replace the oil filter housing on my 2017 G63, which has the same leaking small plunger on the filter housing. I removed multiple components to create enough working space.
When I started removing the T40 Torx bolts on the oil filter housing, I ran into a problem with the bolt located on the bottom driver-side of the housing (I believe it’s the longer bolt). The picture above shows the new oil filter housing, and I marked the location of the bolt that failed during removal.
My T40 bit would not fit properly, so I tried using a T30 on a 3/8 wrench. At first it seemed to grab, but it eventually slipped and the bolt head was slightly rounded or damaged. I tried a few other methods to remove it but had no success.
Since I needed the car for daily use, I ended up reinstalling everything and only completed an engine oil change and coolant replacement.
My plan is to try this repair again during the next oil change. I’m thinking about using a small hacksaw or a Dremel tool to cut a straight slot into the bolt head, then removing it with a large flathead screwdriver.
If anyone has suggestions or better techniques for removing this partially stripped bolt, I would really appreciate the advice.
I also have another question. When I removed the skid plate, two zigzag-shaped spring clips above fell out and I’m not sure where they were originally installed. I reinstalled the skid plate without them for now.
My guess is that these clips help reduce vibration or oscillation between the skid plate and the chassis, but I’m not certain and don’t know where and how to reinstall them back.
Does anyone know the correct location for these zigzag spring clips or how they should be installed on the skid plate?
Any feedback would be greatly appreciated.
Old Apr 27, 2026 | 04:22 AM
streborx's Avatar
Top Answer: 1
G550
Have you tried a bolt extractor ?
https://www.harborfreight.com/multis...ece-58699.html
Old Apr 27, 2026 | 09:21 AM
JPLEE84's Avatar
2017 G63
Originally Posted by streborx
I haven’t tried using an extractor yet because I don’t have one and I’m not sure there’s enough space to hammer the extractor bit into the bolt head. Maybe I might get one and try it next time.
Old Apr 27, 2026 | 10:07 AM
streborx's Avatar
Top Answer: 1
G550
Stripped heads and snapped shanks are a headache for sure. Since you're not re-using the housing (damage is not a concern), grinding or cutting might be your best option, although some bolts can be tough to cut, and clearance to work in seems always a problem. Extracting the stud after removing its head can be tough if dissimilar metals have bonded. Good luck on your next go-at-it, and let us know how it goes.
Old Apr 27, 2026 | 10:59 AM
streborx's Avatar
Top Answer: 1
G550
You might also try "Vampliers" -- they make a vise-grip tool with serrated jaws specifically designed for screw and bolt extraction.
https://vampiretools.com/product/vam...ocking-pliers/
Old Apr 27, 2026 | 12:57 PM
JPLEE84's Avatar
2017 G63
thanks for the comments. I will update this thread later for sure. I will first try to use the locking jaw that below gentleman suggested and then extractor bit with hammering it to grab the bolt. If all these will not work then will cut and make straight groove and unscrew it with flathead driver.
