G Class (W463A) Produced 2019-Present: G550, G63 AMG
dashcam - fitcamx
Old 07-26-2023 | 01:18 PM
RedPill's Avatar
2018 GLC63s, 2021 G63OB, 2021 G63MB, 2022 G63MB
Originally Posted by Chedman13
Thanks! I might have a defective one. When you press and hold the power button, does it stay off?
never used the power button. when i unlock the doors that's when it comes on and when i lock the car (and after the lights go out) it switches off after a few minutes.
Chedman13 (07-29-2023)
Old 08-10-2023 | 03:47 PM
dcarrer0's Avatar
2021 G63; 2018 Aston Martin DB11
Originally Posted by Hodog16
I just installed it tonight and damn it's so easy to do.
John's picture from the original dashcam thread will help you a lot:
Harness picture
You pop off the central piece and then work around the edges of the larger shroud and it should easily pop off without much force. The biggest pain in the rear is the central piece is tied into the larger piece with the plastic anchors (see John's thread again) which you have to free one side by pinching in those barbs in order to get around the rear view mirror.
After that pop off the original harness, plug it into the adapter then connect one end back into the harness and the other to the camera. Pop in the new shroud and central piece and done. Took me like 10-15 minutes total.
Hopefully it works as well as it's designed.
Installation was definitely easy once I knew which cable to use. Use the white cable that goes to rain sensor. Shroud pops off & on. Video looks good. App seems to be pretty good. Will mess with it more later.
Thanks for all the good information on here.
Old 08-10-2023 | 04:04 PM
Chedman13's Avatar
2014 Mercedes-Benz GL63 AMG
Update - everything is working fine now, did a few more resets and that seemed to work.
Have it in my Panamera and just ordered one for my GLB!
Old 11-08-2023 | 01:18 PM
tarik18's Avatar
GLB 250 4matic
Hello. How did install in GLB work? Any issues or concerns? I believe we need HD-2-1168 version.
Thank you
Old 11-08-2023 | 03:45 PM
Chedman13's Avatar
Thank you
no issues.
Old 11-08-2023 | 03:47 PM
tarik18's Avatar
GLB 250 4matic
no issues.
Thank you
Old 11-09-2023 | 03:18 PM
  #32
efathalla's Avatar
2013 S550 SOLD / 2016 S63 SOLD / 2017 GLS450 / 2017 G550 4x4 / 2019 G63 E1 SOLD / 2019 S63 COUPE
I heard good stuff about it, but the mobile app has really bad reviews, any feedback on the app from anyone here?
Thank you.
Old 11-09-2023 | 03:21 PM
  #33
tarik18's Avatar
GLB 250 4matic
My concern is camera heat that some users reported. There was one user on vwvortex that reported camera catching fire during installation.
Old 11-09-2023 | 03:22 PM
  #34
efathalla's Avatar
WOOW
Old 11-09-2023 | 03:37 PM
  #35
tarik18's Avatar
GLB 250 4matic
Although, fitcamx support was responsive and refunded customer.
Old 01-15-2024 | 08:44 PM
  #36
beau315's Avatar
Tesla
Has anyone setup both front and rear cameras or just front only? I’m too chicken **** to do even the front install on my new G63. Looks straightforward though 😩🙈
Old 01-15-2024 | 09:28 PM
  #37
Hodog16's Avatar
2023 G63
Front install is very easy compared to previous dash cam install from second row. Good luck!
Old 01-26-2024 | 08:17 AM
  #38
mog63's Avatar
G63 AMG 2021
I installed the front only myself and it indeed looks great and works smoothly. I won't install the back.
Old 03-03-2024 | 05:03 PM
  #39
Idoccurt's Avatar
2021 Gls 450
so are you a pro at fitcamx install now? I am thinking of buying for 21 gls450. Tricks?
Old 03-03-2024 | 05:26 PM
  #40
dcarrer0's Avatar
Installation was definitely easy once I knew which cable to use. Use the white cable that goes to rain sensor. Shroud pops off & on. Video looks good. App seems to be pretty good. Videos are great. No issues & looks factory.Thanks for all the good information on here.
Old 03-05-2024 | 03:10 PM
  #41
jcn83's Avatar
2022 G63
Safe to presume this works for 550's as well?
Old 03-05-2024 | 03:13 PM
  #42
Chedman13's Avatar
Yes, works on any 2019+ G class. No real tips here, the video in the listing is exactly what I did. First time took 10 minutes as I was really careful. Second time it took under 60 seconds.
jcn83 (03-05-2024)
Old 03-13-2024 | 12:55 PM
  #43
Karbertz's Avatar
Benz Sedan 2018
Received my Mercylion front and rear cameras, also bought the separate hard wire cable to enable the parking mode feature, all seems pretty straight forward to install, but has anyone here actually installed the hard wire cable eg to the under glove compartment fuse box? , which fuse they used etc, any advice appreciated, photos even better.
Old 03-13-2024 | 01:25 PM
  #44
Hodog16's Avatar
2023 G63
Search up the dash cam install thread from like 2019. All the fuses in front are live. You have to use fuses under rear right seat to get a switched one.
Old 03-14-2024 | 09:32 PM
  #45
SLS's Avatar
SLS
1998 Land Cruiser, 2003 SL500, 2024 G63
Ordered this with both the front and rear cameras. I've not installed it yet as I'm inexperienced on how to remove the moldings, pieces etc. to run the wire from front to back. I've watched several videos where they rebuilt a crashed G-wagon which is making me even more apprehensive to do the job. Advice is to not run it along the molding as it can cause leaks when it rains? Anyone know of any good videos on how to remove the appropriate parts to run the cable?
Old 03-17-2024 | 11:32 AM
  #46
mpalsal's Avatar
please share your installation once done. I am looking to do the same thing.
from the video on YT the center piece on the shroud seems to be tricky to remove, if you will, please provide pics.
thanks,
Pop
Quick Reply: dashcam - fitcamx
