Are snow tires an absolute must?
My G 63 arrives in a month and that doesn’t give me a tremendous time left for Winter driving here in the Northeast. Realistically, I’ll be in some combination of Upstate NY and Vermont about 4-5 weeks out of Jan/Feb. Is it worth me braving it and making due, or should I suck it up, order winters, have them swapped for a couple of months and then go back to stock?
This feels like a lot of effort for minimum usage but am all ears.
I live in LA and come from Hawaii so take what I say with a massive grain of salt, but when I picked up my pre-owned 21 G63 from Portland and drove it down to LA I hit small dustings of snow through some passes.. ignorantly thought the truck could handle it on the A/S tires no sweat, I was wrong
Drifted quite a bit and had to very very carefully apply throttle etc... winter tires would have made a big difference 100%
GforMe (11-09-2023)
2013 S550 SOLD / 2016 S63 SOLD / 2017 GLS450 / 2017 G550 4x4 / 2019 G63 E1 SOLD / 2019 S63 COUPE
If you have the stock michelin summer tires then snow tires are a must, you will not make it!!
All season tires, even those with M+S ratings, can be dicey in winter driving. If you want all season tires for year round use, go with a tire with 3MPSF rating. If you're driving more than 5K miles during winter, a set of winter wheels + tires probably makes sense for where you live.
2015 CLS 550 2015 ML 400 Previous 2020 GLB 250 2019 A 220 2005 ML 350 1989 300 E 2001 SL 500
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
Braking has EVERYTHING to do with traction. If a tire exhibits zero traction during braking, a brake caliper clamping a spinning rotor encounters no rotational resistance, the wheel stops spinning immediately, there is no kinetic energy transformation to heat by the brakes, and the vehicle does not stop. ABS is designed to prevent such rotational lockup and differential wheel rotation leading to loss of control. Acceleration and braking both rely on friction (traction) between the tire tread and the road surface.
I also have 22” wheels.
GforMe (11-14-2023)
Yes, I have the Scorpion as well. They are garbage in snow and ice. Definitely change them! As I mentioned above, the issue is braking, not traction under acceleration.
GforMe (11-14-2023)
Traction on slippery roads is not really an issue with the G Wagon. With full time AWD, its weight, and lockable diffs, you can be on summer tires and won't get stuck. The issue is braking, without snow tires.
