Burmester lack of bass?
What’s up with the lack of bass on the Burmester sound system? Is there a sub in this vehicle? My Tesla sounds much better. Any settings I should adjust? I have surround On and bass turned up to 10. And don’t get me wrong, I am not a bass head and don’t listen to a lot of bass heavy music. I’m a classic rock and Tom Petty kind of guy. But the bass in this system is pretty weak IMO.
There's a sub on the rear driver side of cargo area--you can see the grill there.
I've not been impressed with the Burmester system in the G63, and it's one of the things I'm looking forward to in the 2025 as it's supposedly improved with an extra speaker in the ceiling.
I try not to turn the bass too high because on a previous vehicle (21 or 22 I forget), it caused my front lower speakers to permanently rattle.
powershot24 (06-23-2024)
I had a similar issue when I first got my G63. I tried playing around with the settings in the Burmester, and just couldn't seem to get the equalizer settings to my preference. A couple of days later, I decided to try switching up the settings on my iPhone since I get my music in my truck via Bluetooth by way of my iPhone. Boy, what a HUGE difference it made!!! Now my G63 sound system is perfect for me. For whatever tech reason beyond my knowledge, the Burmester system seems to be controlled more by the external iPhone (or Android device, I would assume) settings than those in the system itself.
Give it a try. It was night and day for me. Good luck!
What settings did you change on your iPhone to improve the sound quality?
You can access it on your iPhone by going to "Settings" > then "Music" > then "EQ", which will then provide you will a pretty wide range of music type selections. The "EQ" tab is buried somewhat in the middle of the "Music" tab and a lot of my friends don't even know this feature exists. Just scroll down on the "Music" menu slowly and you'll locate it.
The settings on the iPhone seem to override those of the Bermester. Good luck.
The following 2 users liked this post by AmyC:
MayhemD90 (07-18-2024),
