G Class (W465/W463A) W463 Produced 2019-2024: G550, G63 AMG W465 Produced 2025-
18" wheel fitment on 2020 G550?
Old Apr 20, 2021 | 10:39 AM
tcsracing1's Avatar
2013 G63
Anybody know if 2015 18" wheels will fit on 2020 G550?
Old Apr 21, 2021 | 05:21 PM
streborx's Avatar
Top Answer: 1
G550
The bolt pattern (5 x 130) and center bore (84.1 mm) should be the same.
Old Apr 21, 2021 | 10:10 PM
tcsracing1's Avatar
2013 G63
wondering if they will clear the brake callipers?
Old Apr 22, 2021 | 08:50 AM
streborx's Avatar
Top Answer: 1
G550
The clearance in the axial direction should be OK. If you now have at least 1.5" radial clearance between the inside wheel surface and the top caliper surface, it should fit (assuming you have 20" wheels). I'd contact the 18" wheel seller and ask for dimension specs.
Old Apr 22, 2021 | 11:06 AM
tcsracing1's Avatar
2013 G63
thanks, i have the 18" wheels with winter tires. If i order a new 2021 G550 with 19" wheels, im wondering if it will clear the 18" factory wheels from the older model.
Old Feb 11, 2022 | 10:04 AM
tcsracing1's Avatar
2013 G63
my 2021 G550 will fit 18" wheels from the 2015 G550.
Just need a 30mm spacer to make it look perfect.
Old Feb 11, 2022 | 08:48 PM
3WD's Avatar
3WD
SPONSOR
Car
You'll need spacers for sure.
