G550 Brakes on a G63
Thanks in advance.
* Side note rant: The size of the calipers and rotors on the 63 are absolutely stupid and unnecessary. Some of the worlds best setups are small enough to accept 17" wheels.
The brakes on the G 63 were designed for the increased power of the car.
Put smaller brakes on it and you will run out of stopping power sooner or later.
You get into an accident and you leave yourself open to a lawsuit because you tampered with the cars brakes.
Maybe you should just trade for a G 500.
However, the proper analysis is a G63 going 150 mph vs. a G550 going 100 mph. Stopping the G63 from 150 mph is not a concern as you're probably trying to outrun the flashing lights (lol)!
For me, I would want the G63 brakes on the G550, and that’s the only part of the G63 I would want, otherwise I think the G550 is perfect.
Well hopefully the G63 brakes feel better than in the G550. They are not terrible, but they could use more stopping power. But the G63 is 5% heavier, as you point out, so the brakes will have to overcome that added weight in order to be stronger than the G550.
I have a feeling the G550 brakes can lock up the tires as quickly and firmly fitted on a G63, just as well as the original G63 brakes can….?
(Not claiming this as fact, just trying to understand).
If both setup of brakes can lock up (leaving ABS out of this argument to simplify) the tires, what is the difference?
On a track, racing through the mountains, or other high performance situations, the G63 brakes would do better…. But daily driving, I don’t think it matters….?
Also, I would give up some brake size to add portals any day!
Larger pads and rotors are ideal for drivers such as a friend of mine who likes to hit 80 mph in his GT3 between stop signs in his neighborhood.
That's why a car with larger pads and rotors stops faster and requires less pedal effort to stop. I think it's obvious?
Fade is another matter, and yes, if you cross-drill and vent you will reduce fade. But larger pads and rotors will do nothing to reduce fade on their own.
"The truth of the matter is that most likely, you already have more stopping friction in your stock brakes that you can use" - this is not the point.
Think about it - larger surface area between pad and rotor = faster deceleration for a given pedal force/input.
Fade is related to heat, which is dissipated by venting and/or cross drilling. Actually, a larger pad and rotor will create more heat, not less, which means fade is more likely to occur with a larger pad/rotor. It's the venting and cross-drilling, and materials of the rotor/pad that reduce heat and therefore fade.
op, yes it’s possible. It is unlikely to find this type of retrofit in this site, imo. This is where you’d get no resistance over going bigger and arguments such as undersized master cylinder or improper abs programming would not matter...cause bigger is bigger.
if you went into any custom off-road store, they would be able to help you out. It’s not as though these rotors are a part of the wheel bearings. And besides you’re changing out the axles so you’ve got some welding ahead for brackets anyway.
sounds fun! Don’t let the engineers steer you. They are supposedly building in tolerances for all these broken parts we see on these boards😂. Just kidding there but an engineer may be a little too technical to simply answer yes or no.
pretty sure we don’t have to look too far back to see smaller brakes on a high powered Amg of any type.
