G Class (W465/W463A) W463 Produced 2019-2024: G550, G63 AMG W465 Produced 2025-
Cargo load?
Old Aug 8, 2022 | 08:10 PM
dcarrer0's Avatar
2021 G63; 2018 Aston Martin DB11
Cargo load?
Curious, how much weight will the cargo area in the G550 hold? Need to pic up about 500pds of lifting weights.
Old Aug 8, 2022 | 08:26 PM
streborx's Avatar
Top Answer: 1
G550
Check the label on the driver's side B pillar. Mine says total weight of passengers and cargo is not to exceed 1014 lbs. As long as you're not hauling the body building team too, you should be OK. Make sure the load is distributed and securely tied down.
